Hi I have recently installed simulation cfd2013. installation was successful and i managed to run a couple of simulations, but a fed days i got an error unable to initialize adlm - error code <-104>. i've have multiple attempts of uninstalling and installing but with no success. whenever i try to run a simulation i am now getting this error followed by llicense file cannot be found:ADLM: startup failed:
there are 3 suggested solutions 1) verify licpath.lic file in installation folde. 2) check if installation is not licpath.lic.lic, 3) if there is not one, make one.
These suggestions have not resolved my problem. i know that this has been raised in previous messages, which i have followed, but there seems to be no solution which works. can someone please help?
rob
Hi Rob,
The typical solution for the ADLM: Startup Failure is documented in the following article.
Known Issue - Simulation CFD 2013 Initial Release Regarding Localization
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18708426&linkID=18154757
Royce
Dear Royce,
many thanks for your reply. I had attempted that solution, however i have found that i needed to run the following prior to it. Hope this will be useful to others.
