CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Unable to connect to the selected server computer
9 REPLIES 9
Message 1 of 10
tuhin
2323 Views, 9 Replies
I was getting an error while solving any problem using Autodesk Simulation CFD 2013. The error message shows " Unable to connect to the selected Server Computer". I am attaching the screenshot for your reference. Thanks for your supportcfd.png
9 REPLIES 9
Message 2 of 10
Jon.Wilde
in reply to: tuhin
Are you running from a file stored on your local hard-drive? If not it can cause this issue.
Seems like a silyl question as I know that is one of our example models which get installed locally but just incase.
Also right click on the CFD installation folder in win explorer, go to Properties and Security. Ensure that the 'user' account has full access.
Kind regards,
Jon
Message 3 of 10
in reply to: tuhin
I am currently having the same issue.  I have my file located on the local hard drive, and the installation location has all the correct permissions.  Is there anything else that I can try?
As a side note, it has been a little over a year since I have used Simulation CFD, and it worked previously.  I'm not sure what has changed.
Message 4 of 10
dhalls001
I am having the same issue on my computer. Hovever it was working about 10 minutes earlier.
I have tried restarting with no avail.
Message 5 of 10
in reply to: tuhin
Im having the same problem,
Message 6 of 10
Royce_adsk
in reply to: tuhin
Are you actually trying to do a remove solve or when you look at the solve window are you trying to solve on MyComputer?
It might just mean that you need to resetup your firewalls:
http://knowledge.autodesk.com/support/simulation-cfd/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Thanks!
Royce.Abel
Technical Support Manager
Message 7 of 10
in reply to: Royce_adsk
I am having the same problem. I tried every step, I could think of:
user rights
location of the file
unblocking the fire wall
still the same message.
Could it be a problem that I am running the software on Parallels on a Mac?
I use:
Autodesk CFD 2015
Windows 7
Parallels 9
MacBook Pro
I would be very thankful for any hint...
Bernhard
Message 8 of 10
I fixed this by restarting the service. I had disabled one of the AutoCAD
start up services without realizing it. Make sure that all of the AutoCAD
services are enabled and running.
Message 9 of 10
in reply to: Jon.Wilde
Im having the same problem,Autodesk Simulation CFD 2015
Message 10 of 10
I had same problem in a local solving
Just make sure server service is running (Servermanager.exe)
and delete and re-enter computer name
it worked for me
