CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Unable to apply the resistance material
2 REPLIES 2
ffxue
373 Views, 2 Replies
Hello everybody
I have a problem to apply the resistance material.
I followed the instruction to simulate the HVAC system example in the CFD2013 software, but when I finished all the setting then to click the apply button, the material box is not disappeared. In order to simplify this issue, I only apply the resistance to the rectangular plate, the problem still existed. I used the V10 version before, it never happened, now in the 2013 version, I don't know why I can't apply the resistance material?
2 REPLIES 2
ilyas_drawbridge
in reply to: ffxue
You need to set your fluid material first before setting your resistance material.
ffxue
in reply to: ilyas_drawbridge
Yes, thank you. In V10, all the parts were set air as default, but in 2013, all are unassigned. This is the big difference. Appreciate your reminder.
