Discussion Groups
Simulation CFD
3 Kudos
UI Language change
207 Views, 3 Replies
12-17-2013 07:38 AM
I am trying to change the User Interface Language to English on a localised version of Windows, but with no success. I ran SimCFDconfig.exe as suggested in the Wiki, but it results in a strange hybrid. Part of the interface gets translated to English, whereas the Ribbon remains in German (please refer to the attached Screengrab below).
Do you have any ideas how to fix this issue?
I'd appreciate it.
Mariusz
Product Support
149 Kudos
Re: UI Language change
12-17-2013 08:37 AM in reply to: tenmaryjan
Hi tenmaryjan,
Did you right click to run the config file as admin?
Kind regards,
Jon
Jon Wilde
3 Kudos
12-17-2013 08:51 AM in reply to: wildej
Hi Jon,
thanks for your sugestion - it solved the problem!
Mariusz
0 Kudos
05-31-2014 02:51 AM in reply to: wildej
Thanks a lot! After French and German, now I kinda understand what I'm doing :smileyhappy:
