Discussion Groups
Simulation CFD
Active Member
HomaPumpen
Two Workstations, one for GUI and one for Solver, no connection
231 Views, 5 Replies
07-22-2013 02:14 AM
Hey,
We have one fast Workstation for CFD. GUI and Solver are installed. Now I have installed the GUI (not the Solver) on my CAD-Workstation too. Network licence is working good.
I have configured both computers for using the powerfull workstation as solver from my WS accoring to the manual. The Server tool is running on both machines. I can ping the computer. I have added the entry for the new solver below the "mycomputer" entry with the correct computer name. Windows firewall isswitched off. I am getting an error message when I start the simulation. There is no connection to the solver possible.
What can I do?
Martin
Please use plain text.
Product Support
Royce_adsk
Re: Two Workstations, one for GUI and one for Solver, no connection
07-22-2013 08:32 AM in reply to: HomaPumpen
Hi Martin,
Many times I have seen the need to still configure the exceptions for the firewall even when you turn it off.
Refer to this article on what you need to configure.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18679671&linkID=18154757
Thanks!
Royce
Royce Abel
Active Member
HomaPumpen
07-23-2013 12:37 AM in reply to: HomaPumpen
Hi Royce,
I have set all the rules in the windows firewall. On both computers for incomming and outgoing data. Finaly 14 rules on each computer.
I am still getting the same error. If I run the Job monitor on the client, I can see the Solver-Computer and the status. I can also start a calc. lokal on the Solver and stop it from the client. So communication is possible in both directions.
What else can I do?
Martin
Active Member
HomaPumpen
07-24-2013 04:59 AM in reply to: HomaPumpen
I have found the problem. It works fine if I switch off the Proxy Server in Internet Explorer. It seems that CFD is loading the Proxy settings from IE at startup and uses this for connecting to the solver. Of course this is not necesarry because the Solver computer is in the LAN, no proxy needed to communcate.
Switching off the Proxy is a workaround but no ggod solution because we can not use the Internet.
My question is: Can we tell the CFD software not to use the proxy from IE?
Product Support
Royce_adsk
07-24-2013 07:14 AM in reply to: HomaPumpen
That is a very interesting and unexpected find. I am going to have to discuss this with our development team.
I wonder if there are adjustments to the settings of the proxy server to improve performance?  This would be something for you to take up with your IT department.
-Royce
Royce Abel
Product Support
Royce_adsk
07-24-2013 07:25 AM in reply to: Royce_adsk
When you modified your proxy settings in IE could you instead of turning it off click on the check box 'bypass proxy server for local addresses' and see if that allows the communication to work successfully?
Also, it might help to turn off the 'automatically detect settings' option.
Let me know of your findings with adjusting these settings!
Royce
Royce Abel
