I've been working my way thru the 2014 CFD tutorials. I find the performance of the server is very poor.
Most of the time it takes longer to turn the page than it does to read it. Many times my browser times out and
says it can't display the page. My internet connection is in good health (speed test reports 83Mps download and 53Mps upload).
The issue also seems to impact the wiki help.
I'm hoping someone from Autodesk can send this email to the relevant people.
Is there somewhere I can download the tutorials so I can get on with the learning?
Scott Ainsworth
Solved by Royce_adsk. Go to Solution.
Solved by Jon.Wilde. Go to Solution.
One solution might be a different browser. The other is as you say, local files, which you will find here
The files available for download on that link are only for the self paced training and only contain the car assembly. Is there another link to download the files used in the tutorials from the autodesk wikihelp? Because I've been searching for the folder location and It doesn't show in my system and in this link http://wikihelp.autodesk.com/Simulation_CFD/enu/2014/Help/0083-Tutorial83/0084-Tutorial84/0085-Launc... there is only a path for windows 7, I don know if it's the same for windows 8
Thank you!
Luis
The tutorial model files should be located in the same location for win7 and win8:
C:\ProgramData\Autodesk\Simulation CFD 2014\Tutorials
Does that help ou?
