CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Tutorial files missing in Autodesk Simulation CFD 2015
3 REPLIES 3
maxmarautodesk
2387 Views, 3 Replies
Dear community,
I am a new user of Autodesk Simulation CFD 2015, running it on Windows 7 64bit. Therefore, I thought it is a good idea to start over with the tutorials coming together with the software. I accessed the tutorial section of the help from within the program. Then, I started with the tutorial about the manifold and tried to open the tutorial files as explained there. But the mentioned folders which should contain the necessary files for the tutorials do not exist on my computer!
Can I download the files somewhere?
Or how to solve/circumvent this problem?
Did anybody experience the same already?
FYI, my explorer does show also hidden files and folders and I have also tried the Windows search to find any tutorial folder.
I would appreciate your help very much!
Best regards,
Max
3 REPLIES 3
Jon.Wilde
in reply to: maxmarautodesk
It sounds like this might be an admin rights issue.
Perhaps you need to re-install as admin incase CFD did not have write access to the necessary folders the first time?
Jon
All tutorials are under
C:\Programdata\Autodesk\Simulation CFD\Tutorials
This folder will exist on your machine. If for some reason this folder does not, your installation may not have completed successfully. Run (as Admin) SimCFDconfig.exe and then check for the tutorial folder again
The tutorial files are in fact in the following folder:
C:\ProgramData\Autodesk\Simulation CFD 2015\Tutorials
Thanks to all of you!
