Show only
Search instead for
With Autodesk SIM Pro (multiphysics) the "easy" turbulence model is LES (large eddy simulation). What is the equivalent in CFD 360 that makes convergence easier and less computational expensive? I am not seeing that as an option.
Best to leave the defaults on, rather than make changes to turbulence settings, there are not really any shortcuts here. We change them depending on the model type that is being solved, to improve accuracy. Convergence should not usually be a challenge with the correct settings.
