CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Total heat flux boundary condition
1 REPLY 1
727 Views, 1 Reply
Have a simple question - when I apply a total heat flux boundary condition to two surfaces, does each surface get the heat flux value I put in? e.g. if I put in 300W as the total heat flux and pick two surfaces, does inventor split the 300W into 150W and apply 150W to each of the two surfaces?
-Gaurav
1 REPLY 1
hartogj
"Total heat flux" refers to the fact that the heat flux is the total for a given surface and not assigned on a per unit area basis like it is in the "heat flux" boundary condition. When applying a total heat flux boundary condition, that total heat flux magnitude will be applied to each surface you have selected.
For example, if you have two surfaces selected and then assign a total heat flux of 300W, each surface will be assigned 300W netting 600W of heat.
Jon den Hartog
Product Manager
