is there a tollkit available to export directly from Direct Modeling like the one in Creo 2.0 to avoid the translation to ACIS .sat? Or is this the only way to import Geometry from Creo Elements/Direct Modeling 18.1?
Solved by Royce_adsk. Go to Solution.
Hi Stefan,
There is no plug-in/CAD Connection for Elements/Direct Modeling at this time. You will have to keep working with the acis output.
Personally, I would probably save out a step file and read that into Inventor Fusion and then launch from Inventor Fusion.
Best regards,
