Hi everybody!
I want to simulate thermal comfort of human occupants inside a conditioned space. There are some thermal comfort factors in result quantities which i can't understand fully. There are Metabolic rate, Clothing & Humidity. But if i want to calculate thermal comfort of two occupants with different clothing and metabolic rate in the same conditioned space,how will i solve it?
I can CAD model two occupants and assign different total heat generation to them(metabolic rate), will it affect result as i can only assign one metabolic rate in the thermal comfort factor, Again how can i view thermal comfort of two occupant with different clothing in the same conditioned space?
Thanks! ๐
Have you tried pressing the small blue '?' within that window? It will take you to the relevant help page ๐
As these are global values, you would need to clone your scenario and run each with different Thermal Comfort values and then make a comparison between the two.
Yes i tried clicking help section in the software but there were no clear indication about this.
Thank you! That means i can't assign different clothing to different occupants in a same scenario,can i?
