Discussion Groups
Simulation CFD
Active Member
Rycosso
Thermal Analysis Heat Flux Through Walls
556 Views, 7 Replies
04-22-2013 01:22 PM
I am modeling walls to test thermal performance, and I have found that as my model gets more complex the difference between the interior and exterior heat flux gets larger. I applied a film coefficient boundary condition on the interior and exterior of the wall, and on all the edges I put a heat flux boundary 0.
At first I thought it was meshing, but I still had the issue when I made the mesh as small as the software allows. The problem also goes away if I apply the same material to all layers of the system.
Why am I getting a different heat flux on the interior and exterior of my model?
Please use plain text.
Product Support
Royce_adsk
Re: Thermal Analysis Heat Flux Through Walls
04-22-2013 02:42 PM in reply to: Rycosso
Try running with tight convergence with ADV5. Let us know if that helps!
-Royce
Royce Abel
Active Member
Rycosso
04-22-2013 03:43 PM in reply to: Royce_adsk
I turned the convergence to the tightest that the slider would go, and changed the Advection to ADV5, and my results did not change at all.
Product Support
apolo.vanderberg
04-30-2013 11:23 AM in reply to: Rycosso
Rycosso,
  As your model gets more complex, be sure that the mesh quality through the thickness (of each material) remains at a similar mesh quality. It is possible that your more simplistic models had a better quality mesh through the material thicknesses such that we were able to maintain an energy balance more easily.
There is no need to assign a Heat Flux of 0W on the sides/edges, we automatically assume that an exterior wall without any thermal boundary condition will be treated as adiabatic.
Apolo
Active Member
Rycosso
05-03-2013 11:46 AM in reply to: apolo.vanderberg
Thank you Apolo for the suggestion. I have reduced the mesh in the model to the lowest the software will allow, and the change in the result is negligible. I have also tried the adaptive mesh options, and they do not resolve the issue either.
Thank you for the Adiabatic tip, that will help speed up the model making process.
Active Member
Rycosso
05-16-2013 03:25 PM in reply to: Rycosso
I have even tried the simple wall below to show that meshing could not be the issue. I made this super simplified wall model with 1" thick studs with the settings you described above, and I am still getting different heat fluxes on the interior and exterior.
Product Support
Royce_adsk
05-16-2013 03:35 PM in reply to: Rycosso
That is a 3.6% error which is typically regarded as a reasonable error.
-Royce
Royce Abel
Member
megmac
07-29-2014 10:53 AM in reply to: Rycosso
Hi there.
Please see my post here: http://forums.autodesk.com/t5/Simulation-CFD/Wall-Calculator-Heat-Flux-in-AutoDesk-Simulation-CFD/m-...
I believe I am having a similar problem (i.e., interior surface fluxes do not equal boundary fluxes at steady state).
Did you ever find a resolution to this problem?
Thanks!
