Hi I want to export the results as a TecPlot file, I keep pressing the export button but I do not get a dialog where to save the file and the Simulation CFD shows in the status bar (at the botton) an export message, and after that nothing, I can't find the file in any of the simulation folders.
I have the latest Autodesk Simulation CFD 360 installed on the system.
P.S.: the same is happening if I want to export to FieldView.
Please Advise
Solved by apolo_vanderberg. Go to Solution.
Have you now been able to import these files into Fieldview? I have not been able to use the files I export form Autodesk CFD in Fieldview. I was able to import a very small model that I made of a pipe tee. However, whenever I try to inport larger files I get an error message that says ...ERROR - line NNNNNNN - char4:Expecting variable value
