Is there a way to switch what data is plotted on the x and y axis for the XY plot? For example, I want to plot the vertical temperature distribution, so I want parametric distance on the Y axis and the scalar variable on the x axis.
Thanks!
-Anna
Solved by Royce_adsk. Go to Solution.
Hi Anna,
There is no method inside of the software to make that kind of adjustment to the XY plot. If you need to present the data differently I would suggest that you output the data and create custom plots in Excel.
Best regards
