Mornig to all of you,
I work on a draft water purification. I brings up the current lines in the model to track the trajectory of the incoming water input but my main concern is to modify the properties of the current lines so they are thickened according to the coefficient of viscosity in the mix. So I wanted to show that the water is properly mixed with chlorine.
With COMSOL software it works very well, as explained here:
http://www.comsol.com/model/download/142937/IntroductionToCFDModule.pdf
but I do not know how to get there with the cfd simulation software
please help
Hi, so do the widths of the streamlines change depending on a set variable? This is not something we can do within Sim CFD. Perhaps a scalar analysis might be more beneficial?
I suspected that this was not possible with sim cfd.
I have no track for scalar analysis, can you give me ideas?
thank you in advance.
raphael G.
I can although I suggest our Scalar Mixing Wiki page will be more useful 🙂
Hopefully that helps, it should work well.
