CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
strange component
5 REPLIES 5
547 Views, 5 Replies
strange component
hi
i drew a model in autocad 2013, then i opened it with cfd simulator autodesk 2013, but my model is not full.
there is one component of my model which is empty, not completed, different that mine in autocad and i just don't know why and what can i do against ?
hope you will understand it with these pictures.... thanks
5 REPLIES 5
Jon.Wilde
I suggest that there is something not quite right with that part, or is it just a pattern?
Does it meet the adjacent part perfectly?
Do you need all the detail?
Are you able to test this in CFD 2015?
Jon
in reply to: Jon.Wilde
in this part there one the right something like v piece or components, which is not completed, not full.
i need all detail because it's to analyze it to produce it like that...
i think my computer is not strong enough to use cfd 2015
i ve got lenovo windows seven pro, 64 bits, 4go memory ram...
Jon.Wilde
Should be OK to run 2015, I think.
It is OK to keep the detail, I thought I would ask though.
See if there are any very small overlaps/gaps in the model.
Is the part a pattern or is it totally separate?
How about opening into Inventor Fusion first and into CFD from there?
Jon
i m sorry to disturbed you, because i found my solution: there were two surface in one, like two cube pasted with the same line... that's it,
sorry it's difficult to explain what happened, but thanks for helping.
Jon.Wilde
No problem at all. I suspected the issue would be something like that. Glad all is now OK 🙂
________________________________
Autodesk Limited
Registered Office: One Discovery Place, Columbus Drive, Farnborough, Hampshire GU14 0NZ
Registered in England and Wales, No. 1839239
