hi
i drew a model in autocad 2013, then i opened it with cfd simulator autodesk 2013, but my model is not full.
there is one component of my model which is empty, not completed, different that mine in autocad and i just don't know why and what can i do against ?
hope you will understand it with these pictures.... thanks
Solved by Jon.Wilde. Go to Solution.
I suggest that there is something not quite right with that part, or is it just a pattern?
Does it meet the adjacent part perfectly?
Do you need all the detail?
Are you able to test this in CFD 2015?
Jon
Should be OK to run 2015, I think.
It is OK to keep the detail, I thought I would ask though.
See if there are any very small overlaps/gaps in the model.
Is the part a pattern or is it totally separate?
How about opening into Inventor Fusion first and into CFD from there?
Jon
