CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Steam rising?
1 REPLY 1
paul.bunuan
188 Views, 1 Reply
Steam rising?
Has anyone tried or know if its possible to model steam rising from a surface of water that is subjected to a very hot gas temp? And if so, is it then possible to model a scenario where a steel container is partially filled with water; water is then subjected to a very hot gas at the surface such that it creates steam; and then measure the temperature of the inner steel wall at the steam/water interface to know what difference in wall temperature is as a function of steam?
I've seen other posts that I believe state that simulation cfd does not simulate phase change, so would this case problem then not be solvable with Autodesk Simulation CFD?
Thanks!
1 REPLY 1
Jon.Wilde
in reply to: paul.bunuan
Hi Paul,
I do not think we could do this, no.
The type of phase change we can model is when we have a constant flow passing through a sealed unit with a phase change part way.
Sorry that we cannot help in this instance.
Jon
