For a interior fluid flow analsyis does the fan surface also need to be a Inlet/Outlet surface and be eliminated from boundary conditions ?
Tim
For an external intake fan - does that surface need to be defined as an inlet/outlet in addition to the fan defination.
yes.. but, may be obvious (or not), you should have other "outlets" defined via PRES = 0 so that air is either exhausted or sucked in from external fan
