CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Steady State Fluid Analysis - Fan Surface
4 REPLIES 4
timsefton
616 Views, 4 Replies
For a interior fluid flow analsyis  does the fan surface also need to be a Inlet/Outlet surface and be eliminated from boundary conditions ?
Tim
Tags (1)
4 REPLIES 4
derrek.cooper
in reply to: timsefton
Internal fas are defined by material, not BC. The flow rate or fan curve is defined on the matrial property
Derrek Cooper
Director, Inventor Products
timsefton
in reply to: derrek.cooper
For an external intake fan - does that surface need to be defined as an inlet/outlet in addition to the fan defination.
Royce_adsk
You just define with the external fan bc. No pressure needed.
Royce.Abel
Technical Support Manager
derrek.cooper
in reply to: Royce_adsk
yes.. but, may be obvious (or not), you should have other "outlets" defined via PRES = 0 so that air is either exhausted or sucked in from external fan
Derrek Cooper
