Discussion Groups
Simulation CFD
Active Contributor
tim.sefton
Steady State Fluid Analysis - Fan Surface
374 Views, 4 Replies
11-05-2011 10:03 PM
For a interior fluid flow analsyis  does the fan surface also need to be a Inlet/Outlet surface and be eliminated from boundary conditions ?
Tim
Please use plain text.
Employee
derrek.cooper
Re: Steady State Fluid Analysis - Fan Surface
11-06-2011 05:22 AM in reply to: tim.sefton
Internal fas are defined by material, not BC. The flow rate or fan curve is defined on the matrial property
Active Contributor
tim.sefton
11-06-2011 06:11 AM in reply to: derrek.cooper
For an external intake fan - does that surface need to be defined as an inlet/outlet in addition to the fan defination.
Product Support
Royce_adsk
11-06-2011 07:12 AM in reply to: tim.sefton
You just define with the external fan bc. No pressure needed.
Royce Abel
Employee
derrek.cooper
11-06-2011 09:49 AM in reply to: Royce_adsk
yes.. but, may be obvious (or not), you should have other "outlets" defined via PRES = 0 so that air is either exhausted or sucked in from external fan
