CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Static vs. Total Pressure as an Input
3 REPLIES 3
3838 Views, 3 Replies
Can somebody offer a simple explanation of the difference between static and total pressure when used as an input in SimCFD and advise when the use of each is most appropriate?  For years I have used total pressure as the input in many studies and static as the output (because when starting out with the program I was advised that this was correct) but I have found with a study I am currently running that in some cases using total pressure for the input results in divergence and/or a less accurate result, and changing to a static input seems to correct the problem.
3 REPLIES 3
len.whitehead
For incompressible analyses, static pressure is the recommended inlet condition when simulating a pressure drop. Total pressure is the sum of the static and dynamic pressure, and is often useful as an inlet for compressible simulations.
in reply to: len.whitehead
Then is it possible that using total pressure as an input can result in divergences in an extremely simple model? I am using SimCFD to develop (for reference purposes) a series of curves representing flows through various orifices at pressure differentials between 20 and 100 psig. I'm using a cylindrical volume of ~1 liter, with 10 different orifices ranging from Ø.010 to Ø.375. The orifice length is always 5x the diameter. I initially meshed by selecting the entire model volume and adjusting it to 20%. I was having some trouble at higher pressures with divergence and found that in all cases switching from total to static pressure solved the problem. I also had some results that converged but did not create a smooth curve, with some points being 30-40% off the expected result. Again, static pressure on the input pulled these into line in all but one case. I had noticed that velocity vectors for the questionable results showed some unusual asymmetric patterns. Can this be related to the total pressure input?
waited
using static pressure boundary conditions will enhance your stability.  When total pressure is used as a boundary condition, then P_total = P_static + 0.5 * density *V^2.  From a computational standpoint, we impose P_static on those boundaries, so P_static = P_total - 0.5 * density * V^2.  Having to subtract off the 0.5 *density * V^2 makes this a more non-linear computation.  As the velocities change on the BC surface, we then update the P_static using these velocities and compute the pressure field based on static pressures.  Using P_static on you BC planes allows for a constant prescribed pressure and eliminates the 0.5 * density * V^2 term being factored in.
Dave.
