CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
SST k-omega and boundary layer mesh on inlet and outlet surface
4 REPLIES 4
amy.jin
967 Views, 4 Replies
Hello, I was trying to solve an analysis using SST k-omega model. But when I modified Layer gradation to 1.5 or another value not the default setting on the Boundary Mesh Enhancement dialog, the boundary layer mesh on the inlet and outlet surface disappeared. Why?
Thanks.
4 REPLIES 4
Royce_adsk
in reply to: amy.jin
Hi Amy,
Is this from a ProE model?
As a side note I would not suggest increasing the boundary layer much beyond 1.25. From my testing I find that 1.15 is a decent value to use.
-Royce
Royce.Abel
Technical Support Manager
amy.jin
Hi Royce,
Thanks for your reply.
The model is launched from ProE.
I have tested 1.15, the boundary layer mesh on inlet surface is very strange when refine the mesh, pls see the attachment.
In fact, the problem I cared most is about the boundary layer mesh.
I found that if refine the mesh very fine, the bondary layer mesh on inlet and outlet surface will be likely to disappear. Why?
Another question, when using SST k-omega to solve, the Y+ value is very large more than 300 at boundary layer.
How can I improve this situation?
Thanks very much.
apolo_vanderberg
This at times can be an acuracy issue. Try launching in from Pro/e using a tighter (smaller) absolute accuracy on the proe geometry and see if this helps resolve some of the issues.
amy.jin
in reply to: apolo_vanderberg
Hi Royce and Apolo,
The problem has been solved.
It is really caused by accuracy.
Thanks very much.
