Discussion Groups
Simulation CFD
Active Member
0 Kudos
Solver has exited unexpectedly
380 Views, 10 Replies
03-13-2013 04:02 AM
I am having error telling me that:
"The analysis has stopped because the solver has exited unexpectedly"
I attached  .jpg file.
Product Support
147 Kudos
Re: Solver has exited unexpectedly
03-13-2013 07:57 AM in reply to: mrnfs
Would you be able to describe your study or share a cfz file?
Are you running from a local drive?
Jon Wilde
Active Member
0 Kudos
03-13-2013 11:34 PM in reply to: mrnfs
File is bigger than 1,5 mb
Product Support
147 Kudos
03-14-2013 12:38 AM in reply to: mrnfs
Dropbox folder on it's way!
Jon Wilde
Active Member
0 Kudos
03-14-2013 02:30 AM in reply to: mrnfs
uploaded
Product Support
147 Kudos
03-14-2013 02:36 AM in reply to: mrnfs
I see it, thanks.
Please could you walk me through what this is and what the goal is?
You seem to have a 1 psi pressure coming from the solid part of a pipe, into what looks to be a sealed chamber, separate from the main domain, both of which are a little strange to me, what is the intention here?
Many thanks,
Jon
Jon Wilde
Active Member
0 Kudos
03-14-2013 03:04 AM in reply to: mrnfs
It is a part of crystallizer with water coolling. I want to see water flow betwen shells, but internal volume would not fill & thats why I want to find gaps & opennings like on the video
http://wikiassets-video.s3.amazonaws.com/c7ae56aa82fc14139c447415e286e8a78e83aa01/How_To_Generate_an...
Product Support
147 Kudos
03-14-2013 03:48 AM in reply to: mrnfs
Ah, I see, this makes more sense now.
Have you tried capping off the model in CAD? By adding additional parts to the holes (extruding cylinders from the ID of each - use 3x diameter on the inlets and 5x on the outlets)?
Once you have a hollow but sealed volume in CAD and read it into CFD, the void fill will happen automatically and new created parts will be listed in the output bar.
I assume you are not interested in running anything outside of the unit itself?
Jon Wilde
0 Kudos
03-14-2013 05:33 AM in reply to: mrnfs
I do not want to hijack this thread but just out of curiosity, I posted the same exact error message a day before this thread got created and got no reply. Is there any reason why this issue is getting attention and mine is not getting any feed back ? Is there something that I'm missing.
Best regards
Jonathan Matteau
Ingénieur junior mécanique / Engineer junior mechanical
Product Support
147 Kudos
03-14-2013 05:44 AM in reply to: JMatteau
Hi Jonathan, it looks like it just got missed, the downside of forums! Let me send you a Dropbox link and we can work through it but using your thread to keep things organised :smileyhappy:
Jon Wilde
