CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Solver exits unexpectedly
6 REPLIES 6
1396 Views, 6 Replies
I'm performing an analysis on a simple liquid cooled cold plate and until recently I have had no issues with the solver and have gotten good results. I have now moved to a new faster workstation and upon running any of my old models the solver exits unexpectedly without any warning (no crash, the "go" button simply changes to "stop"). I looked into the log file and found the following messages :
 [16:26:37] Solver for <filename> exited at Fri Jan 25 16:26:36 2013 on <mycomputer> with status = 0 and code = 255
[16:26:37] Unable to inject glr
[16:26:37] Unable to inject gls
[16:26:37] Unable to inject glv
I am still using an old version of CFDesign so hopefully one of the old CFDesign support guys like Royce can help me.
Dave
6 REPLIES 6
Hi Everyone,
First of all, thanks for nothing. I managed to finally solve the problem on my own.   Smiley Frustrated
If anyone ever comes across the same issue where an older version of the solver will not run on a newer Xeon workstation with more than 8 cores, here is the solution. Simply go into your bios and reduce the number of CPU cores down to a total of 8 (in my case since my workstations all have 2 CPUs, I set the maximum to 4 cores per CPU). I tried this fix on a number of 12 and 16 core Xeon E5 workstations and it solved the problem in every case.
David
AnnWinter3287
Just had the same problem, but on the 360 cloud server:
[16:15:47] Unable to inject glr
[16:15:47] Unable to inject gls
[16:15:47] Unable to inject glv
What could cause this??
yebyps
in reply to: AnnWinter3287
Does this look familiar to anyone?
Vonkarman
in reply to: yebyps
Hi @yebyps
Never seen this issue while meshing, but I bet the CAD file is not clean enough. Use Model Assessment Tool to track potential issues, interferences and tiny gaps.
http://help.autodesk.com/view/SCDSE/2019/ENU/?guid=GUID-13936C3E-D5D7-48E3-872B-987BA04ED692
yebyps
in reply to: Vonkarman
That's an interesting possibility.  Do you know if the model assessment tool is accessible from CFD 2017?  In this particular case I would be surprised as the model is closely derived from the Tutorial model with very simple geometry.
Vonkarman
in reply to: yebyps
Well, I am not sure about cfd2017 and Model Assessment Tool. Information about the release at that time should be written on the User's Guide.
If you are using a slightly derived geometry from a tutorial, then it's even more interesting. Can you share a .cfz file?
If not, and you 100% the geometry is clean, I'd suggest two things:
1- You can open the broken .cfdst model you have. Update it with the original cad geometry file from the tutorial and see if you can mesh it.
2- if not, try to mesh a simple cube. (if this works, then you know for sure the problem comes from the geometry)
Last idea would be to uninstall and reinstall?
