I'm having trouble simulating the attached model, i recieve the generic error "Solver Exited Unexpectedly" just after "Processing Input" is displayed in the message window. I'm looking through this page to get some insight as to the problem, the following summarises my efforts so solve this problem
Memory Problems - This is a large mode, about 6 million cells, but i have successfully solved large models on this machine (10GB RAM). During volume meshing memory usage is at 95%, but when the error occurs it is only at 50%.
Poorly Posed Setup Parameters - i've checked all materials and boundary conditions to make sure they're physically sensible, i think maybe this is a meshing issue so i'm attempting to refine the mesh parameters, so far with no luck
File I/O Errors - The files are located on the C drive, there is plenty of free space for the output files and all files have full access(read/write/modify) for all users
Incompatible Scalar Diffusion Coefficient value - i'm not using scalar diffusion coefficients
Is there anything else i should be looking into?
Note: i attempted to attached a share file with the setup parameters, but recieved an error from the forum "The contents of the attachment doesn't match its file type". I guess it's not my night. I can upload the file to a dropbox if needed.
Please do share the CFZ file with us and then we can hopefully help.
Jon
Just tried to upload the cfz file again, the eroor i had before seems to have gone away but now the system reports that the file size is too large. How else can I upload the file?
Can you use Autodesk 360 or Dropbox?
