Discussion Groups
Simulation CFD
Active Contributor
RAALVM
Slip/Symetry as adiabatic walls?
95 Views, 1 Replies
11-21-2013 11:58 PM
On solid region where I have adiabatic wall can slip/simetry can be use insead?
Please use plain text.
nmuoio
Re: Slip/Symetry as adiabatic walls?
11-22-2013 09:54 AM in reply to: RAALVM
Absolutely. If the solid region does not contribute to the solution, other than to define the geometry, then it can be suppressed. Suppressing a volume is done while defining materials. The slip/symmetry BC would not be necessary, as any wall that does not have a BC is assumed to be insulated.
