Discussion Groups
Simulation CFD
Member
0 Kudos
simulation of missile
324 Views, 6 Replies
07-03-2012 07:19 AM
Can we do simulation of missiles in autodesk simulation cfd 2013 so that all cases are considered?
Product Support
232 Kudos
Re: simulation of missile
07-03-2012 08:13 AM in reply to: pranaykiran.rana
We are going to need more detail on what you are trying to do.
Royce
Royce Abel
Member
0 Kudos
07-05-2012 07:13 AM in reply to: Royce_adsk
taking other parameters as constant and changing only the nose shape of missile i want to know the change in drag coefficient,pressure at tip ,temperature profile and  everything related to cfd. can i do that in this ?
Product Support
232 Kudos
07-05-2012 07:41 AM in reply to: pranaykiran.rana
What do you expect the speed of the missle to be?
Royce Abel
Member
0 Kudos
07-05-2012 07:54 AM in reply to: Royce_adsk
for a range of 50 km and its max mach num of 4
Member
0 Kudos
07-06-2012 09:07 AM in reply to: pranaykiran.rana
the speed of missile may be around 600 m/s
can i get the temperature profile at the nose assuming air as compressible?
Product Support
232 Kudos
07-11-2012 11:31 AM in reply to: pranaykiran.rana
Yes.  Please review the compressibility documentation:
http://wikihelp.autodesk.com/Simulation_CFD/enu/2013/Help/0407-Learning407/0726-Guidelin726/0761-Com...
-Royce
Royce Abel
