CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Simulation CFD Licence error while starting
1 REPLY 1
458 Views, 1 Reply
I get this message when I try to start Simulation CFD 2013 32bit
I have been using it with a students licence for a month. suddenly it stoppend opening and started giving an error message.
I Can not resove this issue even if i tried reinstalling it.
I have Autocad 2012, Inventor Fusion 2012 and they are running properly.
1 REPLY 1
OmkarJ
Try and see if this works:
Open following file using notepad:
C:\Program Files\Autodesk\Simulation CFD 2013\licpath.lic
Make sure it has following text in the first line:
SERVER 127.0.0.1 000000000000
Make changes so that it has the text above and save.
A workaround that may work...
Suggest make a backup of licpath before doing these changes so that in case if the workaround doesn't solve the problem you may want to replace it with original file.
Cheers
Omkar
