Recently SP1 was released for Simulation CFD 2014. You do not need to uninstall your current installation (this was required for 2013 SP1) since this is a patch over your current installation.
*** Remember if you upgrade your desktop and you run remote solves on another machine that machine also needs to be running SP1.
http://usa.autodesk.com/getdoc/id=DL21918078
Solved by Royce_adsk. Go to Solution.
Royce,
Where do I find SP1? I've checked the subscription center and anything I've downloaded for Simulation CFD 2014 seems to be the original release, not a service pack.
Erik
Dear CFD users,
Do find the enclosed link for "service pack-1" for ASIM CFD 2014 for 64/32bit systems.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21918078&linkID=18154757
Ajay
Is it possible for you to try a different browser or maybe the office blocks the file from being downloaded? If the office network is blocking the download, maybe ask IT to download the file for you?
I just tested the link and it worked on my end.
I take it this is not for Simulation Pro 360?
Is that maintained as a separate product with it's own service packs?
