Discussion Groups
Simulation CFD
Product Support
232 Kudos
Simulation CFD 2014 SP1 Available!
641 Views, 8 Replies
07-24-2013 08:54 AM
Recently SP1 was released for Simulation CFD 2014.  You do not need to uninstall your current installation (this was required for 2013 SP1) since this is a patch over your current installation.
*** Remember if you upgrade your desktop and you run remote solves on another machine that machine also needs to be running SP1.
http://usa.autodesk.com/getdoc/id=DL21918078
Royce Abel
Active Member
1 Kudo
Re: Simulation CFD 2014 SP1 Available!
08-16-2013 10:32 AM in reply to: Royce_adsk
Royce,
Where do I find SP1?  I've checked the subscription center and anything I've downloaded for Simulation CFD 2014 seems to be the original release, not a service pack.
Erik
Product Support
232 Kudos
08-16-2013 02:05 PM in reply to: Erik.Gifford
Did you click on the link in my message above?
Royce Abel
Active Member
0 Kudos
08-24-2013 01:29 AM in reply to: Royce_adsk
Dear CFD users,
Do find the enclosed link for "service pack-1" for ASIM CFD 2014 for 64/32bit systems.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21918078&linkID=18154757
Ajay
Active Member
0 Kudos
08-30-2013 01:12 AM in reply to: ajay.sim1
I cannot download the 64bit version...
other download link?
Product Support
232 Kudos
08-30-2013 07:05 AM in reply to: fscheunp
Is it possible for you to try a different browser or maybe the office blocks the file from being downloaded?  If the office network is blocking the download, maybe ask IT to download the file for you?
I just tested the link and it worked on my end.
Royce Abel
Active Member
0 Kudos
08-30-2013 07:07 AM in reply to: Royce_adsk
Thank you for the answer.
I contacted the support. --> solved!
Greetings Frank
0 Kudos
09-11-2013 02:10 PM in reply to: Royce_adsk
I take it this is not for Simulation Pro 360?
Is that maintained as a separate product with it's own service packs?
Employee
65 Kudos
09-22-2013 06:00 AM in reply to: dmytty
Correct - Sim 360 Pro receives separate updates. We will post in this forum (and others) when it is available.
