Hi all,
I have been trying to simulate smoke and fire in a confined space. Attached is the case I have been trying to run, but I just couldnt get the scalar and temperature to convect out into the air volume. Can anyone kindly help me out on this one? Thanks!
Hi
looking at a the model briefly here are some points to consider:
Regarding the 100m size, I suspect it might be a matter of units conversion when CFD read in my .sat file. Back in my inventor, I actually moved the fire block above the ground by 50cm. Will get that fixed.
But are there any critical mistakes that I've made in the configuration?
- I know the run has to be transient but are the boundary conditions set to steady state? like the scalar, the velocity inlet, etc?
- is the time step of 0.05 appropriate? there isnt any units so I'm assuming it's in seconds.
- is incompressible auto forced convection the correct choice to use?
- I've set the air to variable but are there any internal changes required?
- ultimately I cant seem to convect the smoke and heat up into the room after a few hundred iterations.
