Discussion Groups
Simulation CFD
New Member
0 Kudos
Simulating Peltier device
196 Views, 3 Replies
03-18-2013 12:44 PM
Is it possible to simulate Peltier device in Autodesk Simulation?
107 Kudos
Re: Simulating Peltier device
03-19-2013 03:55 AM in reply to: janusz.wojtowicz
If you describe what it is and what you want to simulate, you may get more replies from people who know CFD well but not what Peltier device is :smileyhappy:
OJ
New Member
0 Kudos
03-19-2013 09:40 AM in reply to: janusz.wojtowicz
Peltier device is also known as a TEC thermal electric cooler. It is a heat pump that pushes heat between two ceramic plates when current is present.  I have a system comprised of part to be heated, Peltier device, and heat sink.  I would like to know how temperature of the part is changing when different current is applied.  In the past BRNI was considering developing this feature in CFDesign but I am not sure if it was ever implemented.
Product Support
149 Kudos
03-19-2013 01:10 PM in reply to: janusz.wojtowicz
Simple answer: Yes. Take a look in the Materials section, you will find TEC's
Jon Wilde
