Helo ,
In the context of water treatment , I have a simulation exercise to perform, which is as follows:
I have to simulate a mixture of water and chlorine in order to monitor the mixture to know the concentration of chlorine in the water knowing that the water enters the mixing zone through the rectangular entrance on side 1 with a specific flow. It also has the chlorine gas by a liquid duct which enters through conduit 10 diameter . When the output level is achieved on the face 2 , the fluid can now flow outwards , the goal is to determine the amount of chlorine and water to achieve the level of discharge .
I have to work on the simulation software CFd and I have trouble with the boundary conditions
simulation should look like this :
I need help on the boundary conditions and the simulation procedure .
Along the file Cao the contact area of the two fluids
thank you mix
