I've run into a good few issues getting my sim to the point that it's at now, and I think I've gotten past most of the Win8.1/installation related issues. I've moved all of the project files over to my C:/ drive; they were originally on an internal storage volume. I'm new to CFM, but I've got enough experience with Inventor to be comfortable with the interface. I've spent a few days' free time reading through the wikihelp trying to get this sim to work, and I keep getting the "The Analysis has stopped because the Solver has exited unexpectedly" error.
The goal of the design is to keep two power-mosfets cool. The Mosfets are represented in the sim by the copper pieces that are flush-constrained to the face opposite the inlet/outlet ports. They are through-hole mounted in the circuit design, so the Compact Thermal Model approach wouldn't quite work, but I don't know that my current approach is that much better.
If I supress all parts of the imported model except the water, I can solve for flow and heat transfer, though the heat transfer information is useless at that point. If I add any of the parts back in to the simulation, it solves as far as "Meshing..." then quits with the aforementioned error message.
Thanks for your help
Josh
Solved by Jon.Wilde. Go to Solution.
I made a few changes:
The mesh on the solids is pretty coarse, often only 1 element through the thickness, consider refinement.
Jon
Thanks Jon,
At its current rate, the sim will be done around 2am; hopefully it's worth it.
I am curious as to the purpose of the radiation boundary constraint though. Is it just an easier way of redefining emittivity as opposed to editing the material?
Josh
