CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Sim CFD 2012, Fusion, and Win8.1
6 REPLIES 6
mark
390 Views, 6 Replies
Good day,
I have been using Fusion to launch models into Sim CFD 2012. I recently upgraded to Win8.1, and Fusion now seems to be broken (compatibiity issues, according to Windows).
What options do I have? I have installed Fusion 360, but there doesnt seem to have been any integration with Sim CFD.
Mark
6 REPLIES 6
hartogj
in reply to: mark
Hi
Correct - Inventor Fusion 2013 R1 is not supported on Windows 8.1.
At the moment there are two alternatives for you to consider:
1) Fusion 360 is a possibility but, as you mention, there is no direct workflow with Simulation CFD.
2) We are preparing a simulation-specific tool that will connect with Autodesk's Simulation Mechanical, CFD, and Moldflow products. Known as SimStudio, the geometry modeling tools are available as a beta today and will be available with the commercial products in the future. Current customers can sign up for the beta here - we'd love to get your feedback on it:
https://beta.autodesk.com/callout/?callid=700D8DF29CC2483CAC0AE931C52ADBA9
Jon
Jon den Hartog
Product Manager
mark
in reply to: hartogj
Thank you Jon.
1. I have applied for the SimStudio beta. I look forward to trying that.
2. Re Fusion 360, your reply implies that it can actually be used: is that by exporting the model and then manually opening with CFD Sim? Or another way?
3. I know its a long shot, but I have seen some forum posts claiming that Fusion 2012 runs on Win8.1?
Mark
hartogj
in reply to: mark
The workflow will still be an exported neutral file (ACIS/SAT, STEP, etc) from Fusion 360. There have been some recent changes to the Fusion 360 export workflow that make this a bit smoother than before, but it is still a manual export process.
I am not sure about Inventor Fusion 2012 on Windows 8.1. One thing that is certain is that it was created well before Windows 8.1 existed. If it works that's great but it is not something that was tested or supported.
Jon
Jon den Hartog
Product Manager
mark
Hello again Jon,
Before I install the SimStudio beta, will it work with sim CFD 2012?
Mark
mark
in reply to: mark
Hello again Jon,
Mark
hartogj
in reply to: mark
Thanks for posting this q again Mark
For using SimStudio with older versions of Sim CFD (such as version 2012) the workflow is to save out a neutral file like an SAT and then read it in.
New versions will have a direct connection.
Jon
Jon den Hartog
Product Manager
