I have a system operating at 510psi and need to analyze the flow. I'm not sure how to set this up. I've looked into 'compressible flow' but I don't think this fits because I'm not compressing the gas with the actual flow. Here are my conditions:
Ambient pressure = 510 PSIG
Flow Rate = 4.7 CFM
Flow gas = 98% He, 2% O2
On systems that are at 1 ATM, I simply create a boundary condition at the inlet for the flow rate and a 0 PSI condition at the exit. Can I simply create a new flow material that is the corresponding density (of the He/O2 mix at 510 PSI) and set up the analysis the same way?
Thanx in advance for your help.
I think first we need to clarify Compressible. This is used if we are likely to see high enough mach number to cause the gas density to change. To start with, run incompressible and take a look at the flow speeds and maximum mach number to decide if we need to switch to a compressible model. Post up the results from your first analysis and we can help you decide.
You could create a new material for sure, is it different enough from pure helium to be worth it? Changing the fluid density to suit the higher pressure would be fine, although if we need to switch to compressible, you would need a material where the density is able to change.
You can increase the environmental pressure by right clicking on Materials and increasing the value from ambient up to the desired level.
If you can run incompressible, start with a modified material and let's see what the results direct us towards. Then we can look to change the environmental conditions etc.
Jon
Thanx Jon. I don't think the flow will be high enough to be compressible. I didn't realize that there was an ambient pressure setting in the material as well. That sounds like what I will need. I'll run it and let you know what happens.
I ran a test (not my actual device, as I'm still waiting on files) to see if I could see any difference with the changes you suggest. I ran the first test with the standard He and the second with the ambient pressure set to 510psi. The results were identical. Would you expect this?
