Discussion Groups
Simulation CFD
Active Member
kpoersch
Accepted Solution
Setting several time step sizes and number of iterations
128 Views, 1 Replies
10-10-2013 08:33 AM
Is it possible to set several time step sizes and number of iterations with one start klick? For example running the simulation with a time step of 0.01s the first 400 iterations and the run it with 0.001 the next 200 steps, without having to restart the simulation. Maybe it is possible with a script?
Please use plain text.
Product Support
Royce_adsk
Re: Setting several time step sizes and number of iterations
10-10-2013 10:33 AM in reply to: kpoersch
Hi Konstantin,
There is no method within the UI to setup a custom timestep procedure. When I do require this workflow for complex transient analysis I take advantage of scripting.
Royce Abel
