Is it possible to set several time step sizes and number of iterations with one start klick? For example running the simulation with a time step of 0.01s the first 400 iterations and the run it with 0.001 the next 200 steps, without having to restart the simulation. Maybe it is possible with a script?
Solved by Royce_adsk. Go to Solution.
Hi Konstantin,
There is no method within the UI to setup a custom timestep procedure. When I do require this workflow for complex transient analysis I take advantage of scripting.
