I have a plate (solid) that I want to assign a constant temp (50C) to. I seem only to be able to set volumes as a heat generation BC.
I am setting a velocity and temperature to a air stream and I want to have h calculated off of the plate surface.
Thank you.
Just set every external surface of the plate to the same temperature boundary condition.
Cheers,
