Is it possible to simulate Sand in Autodesk CFD?
Like sand running inside a pipe?
Solved by Royce_adsk. Go to Solution.
You could try to use our erosion model technique, but you are going to have the limitation that in the erosion model we do not model the particle interaction. I would assume with something that is designed to move lots of sand that may be of importance.
Eitherway, I would give it a shot with the erosion model we have.
