Discussion Groups
Simulation CFD
0 Kudos
Sand Simulation
218 Views, 3 Replies
08-14-2013 01:14 PM
Is it possible to simulate Sand in Autodesk CFD?
Like sand running inside a pipe?
Product Support
232 Kudos
Re: Sand Simulation
08-15-2013 12:32 PM in reply to: mingyar
Are you looking to study erosion?
What are you goals and could you go into more detail?
Royce Abel
0 Kudos
Re: Sand Simulation
08-15-2013 01:00 PM in reply to: mingyar
Yes Im trying to study erosion inside pipes, with sand transfer machines.
Product Support
232 Kudos
Re: Sand Simulation
08-15-2013 01:09 PM in reply to: mingyar
You could try to use our erosion model technique, but you are going to have the limitation that in the erosion model we do not model the particle interaction.  I would assume with something that is designed to move lots of sand that may be of importance.
Eitherway, I would give it a shot with the erosion model we have.
Royce Abel
