Where can I find sample/example models to download or that comes packaged with SIM CFD, that go along the wikihelp examples http://wikihelp.autodesk.com/Simulation_CFD/enu/2013/Help/0407-Learning407/0408-Example_408
Solved by apolo_vanderberg. Go to Solution.
As you go in to each of the examples they will list where the files are stored.
Open the assembly in your CAD system from the appropriate folder.
In Windows 7, the geometry files are located in:
Program Data\Autodesk\Simulation CFD 2013\Examples\CAD\
or
Program Data\Autodesk\Simulation CFD 360 2013\Examples\CAD\
If you do not see the Program Data folder...
In Windows XP, the geometry files are located in:
Documents and Settings\All Users\Application Data\Autodesk\Simulation CFD 2013\Examples\CAD\
or
Documents and Settings\All Users\Application Data\Autodesk\Simulation CFD 2013 360\Examples\CAD\
Apolo's comments are probably what you are looking for, but this information might help other users as well. Especially ones that don't have access to the internet or the wikihelp system is running slowly.
How to download and install the Simulation CFD Local Help
