Discussion Groups
Simulation CFD
Active Contributor
amy.jin
Same model launch to v2014 Error but v2013 OK
88 Views, 2 Replies
11-21-2013 12:59 AM
The same model can be launched to v2013 successfully, but to v2014 error appeared.
I have tested several model using UG ProE and Parasolid, the same error appeared.
Why? Is there anybody who can give me some advice?
Thanks very much.
Please use plain text.
Product Support
apolo.vanderberg
Re: Same model launch to v2014 Error but v2013 OK
11-21-2013 01:26 PM in reply to: amy.jin
Amy
I would suggest you start a case so that we can go through specific models and see what is different between the two and what might be causing it.
Apolo
Active Contributor
amy.jin
11-25-2013 12:46 AM in reply to: apolo.vanderberg
Hi Apolo,
Pls help me to check this model.
http://pan.baidu.com/s/1M97j
Thanks very much.
Amy
