CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Same model launch to v2014 Error but v2013 OK
2 REPLIES 2
amy.jin
374 Views, 2 Replies
The same model can be launched to v2013 successfully, but to v2014 error appeared.
I have tested several model using UG ProE and Parasolid, the same error appeared.
Why? Is there anybody who can give me some advice?
Thanks very much.
2 REPLIES 2
apolo_vanderberg
in reply to: amy.jin
Amy
I would suggest you start a case so that we can go through specific models and see what is different between the two and what might be causing it.
Apolo
amy.jin
in reply to: apolo_vanderberg
Hi Apolo,
Pls help me to check this model.
http://pan.baidu.com/s/1M97j
Thanks very much.
Amy
