CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Rotating regions
3 REPLIES 3
n.jacky
613 Views, 3 Replies
Rotating regions
Hello everybody,
I would assign some rotating regions. I have already done it a lot of times  but for this case, it's seem to be impossible. I have no warning messages but the rotating region isn't created. I click on the assignment button but nothing happens.
Can i have some advices?
Thank a lot
3 REPLIES 3
ryan.arnaudin
in reply to: n.jacky
You will need to apply the neighboring fluids before applying a rotating region. Have you checked this?
HHOA1307
in reply to: ryan.arnaudin
And how can I apply neighboring fluids?
I get this error: "No neighboring fluids found"
Thank you.
ryan.arnaudin
in reply to: HHOA1307
The rotating region must be contacting an assigned fluid volume, so apply the fluid materials before setting up your rotating region. One workaround is to select all volumes when you first enter into the materials task and assign air, then go through volume-by-volume and assign the proper materials.
