Discussion Groups
Simulation CFD
Member
karldonitz
revit to CFD 2013 error
623 Views, 4 Replies
05-21-2012 06:20 AM
Hello
Finally i could start cfd 2013 with license.
but there is another problem to using this software
At first, i tried to using this program for analyze fluid and heat transfer with revit
but after i activated CFD Icon in the revit, there is a error.
after they succesed to transfer revit to CFD, this program just shut down.
How can i use revit with cfd 2013?
or is there are other problems in my computer?
Please use plain text.
Product Support
Royce_adsk
Re: revit to CFD 2013 error
05-22-2012 12:06 PM in reply to: karldonitz
Hi karldonitz,
Could you test launching from Revit with just a very simple model to confirm that the installation is ok?  What if you just created a simple mass and launch with that.
Royce
Royce Abel
Member
karldonitz
05-22-2012 09:52 PM in reply to: Royce_adsk
Hi royce
I have same problem when i transfered just simple mass in revit to CFD 2013
Also, when i imported this mass on cfd2013, same error appears in my moniter.
I think there is no problem on program because i directly downloaded it from student site of autodesk.
here is error printed on my moniter
problem event name : APPCRASH
Error Module name ; StackHash_8968
Error Module Version : 6.1.7600.16385
Error Module Time Stamp : 4a5bdadb
Exception code : c0000374
Exception offset : 000c283b
OS Version: 6.1.7600.2.0.0.256.1
P.S There is severe problem on program. If you install these programs on other language (In my case, I installed it in Korean).
Program can't read Locale file because data type is not written in 'en-US' and
there could be ADML start up failure when starting program.
See attachments below.
Sometimes, Data type 'en-US' could be Kor or other things after installation, and this could make Failure in start.
Product Support
Royce_adsk
05-29-2012 12:06 PM in reply to: karldonitz
Does this KB article address your issue?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18708426&linkID=18154757
Royce
Royce Abel
New Member
csalaveria-chaminade-stl
10-01-2012 06:59 AM in reply to: karldonitz
Hello to everyone,
I am unable to find the WSCommCntrData in the processes.  I've tried the other troubleshooting help and cannot get past the splash screen.  Any suggestions would be great.  Thanks.
