Discussion Groups
Simulation CFD
Member
jbadura
Results presentation / periodic conditions
105 Views, 2 Replies
10-28-2013 12:36 PM
Hi all.
I have simulated pressure distribution at 1/12 of entire spiral groove sealing ring by applying periodic conditions. Now I want to present results on entire ring by multiplying those 1/12 parts.
Is it possible? If so, how should I do it? If no, are there any tricks to gain that result?
Please use plain text.
Product Support
apolo.vanderberg
Re: Results presentation / periodic conditions
10-29-2013 01:28 PM in reply to: jbadura
Under the View tab you can Mirror your results, however this will only give you twice what you are seeing right now and typically used for models where the face is symmetric, not periodic. We do not have a method of mirroring/patterning the results of a 1/12th slice to generate a full 3D model
Member
jbadura
10-31-2013 05:12 AM in reply to: apolo.vanderberg
