CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Results presentation / periodic conditions
2 REPLIES 2
257 Views, 2 Replies
Hi all.
I have simulated pressure distribution at 1/12 of entire spiral groove sealing ring by applying periodic conditions. Now I want to present results on entire ring by multiplying those 1/12 parts.
Is it possible? If so, how should I do it? If no, are there any tricks to gain that result?
2 REPLIES 2
apolo_vanderberg
Under the View tab you can Mirror your results, however this will only give you twice what you are seeing right now and typically used for models where the face is symmetric, not periodic. We do not have a method of mirroring/patterning the results of a 1/12th slice to generate a full 3D model
in reply to: apolo_vanderberg
