Discussion Groups
Simulation CFD
Active Contributor
1 Kudo
Results not visualizing correctly
103 Views, 3 Replies
06-06-2013 10:28 AM
I tried to run a simulation using Autodesk Simulation CFD 360 (I have been using Autodek CFD before). The model had about 30 million elements. I started the analysis by hitting solve. Later when I check the status, the analysis seems to be finished, looking at the Simulation Job Manager. The convergence plot seems to be converged as well. But when I look at the visualization window, there are no outputs. It almost seems like the analysis is still at 0 Iteration. I tried to pull up the component thermal summary file also. In this case also, the numbers seem to be from 0 Iteration. Please suggest a solution to this.
Product Support
54 Kudos
Re: Results not visualizing correctly
06-06-2013 12:32 PM in reply to: kabindrabhattarai
For 30million elements (and depending the number of intermediate results you were saving) we need to zip and download all the results back from the cloud. Depending on your internet connection this can take some time to retrieve
Active Contributor
1 Kudo
06-06-2013 12:38 PM in reply to: apolo.vanderberg
Thanks for the response.
I was seeing all the graphs of temperature, pressure, velocities, etc. in the convergence plot window though. Does that mean even though I'm seeing the graphs in the convergence plot window, the results have not been downloaded yet?
Product Support
54 Kudos
06-06-2013 12:40 PM in reply to: kabindrabhattarai
Check the simulation job manager as it should indicate the status  and is more than likely still downloading the results
